MEP 802A Fix-up Thread
CallMeColt
1,633
Wilson County, Texas
Everyone,
New member here. Finally got myself an MEP 802A for use at my off grid place & as backup at home.
Going to document what I do to it here. I have $200 in parts on order for repairs. Going to do some step-by-step videos & upload to YouTube that I will share here for the community.
I've been reading the site for a while & figured I'd join. Good information.
CallMeColt
1,633
Welcome, you've found THE best place for info & help with gennys. Post some pics for us, may give you a few suggestions.
I plan to take some. It's a unit reset in 2006. Purchased from a retired couple that got it in preparation for hurricanes but got way more than expected.
Demoh
26
St Pete, FL
Welcome to SS! Good choice going 802... an underrated gem.
Agreed, I run 802 as my primary backup source even though I have a handful of 803s. my 3ton ac and heatpump water heater have no problem with it. Last weekend did a nice run on it, 5 hours @5kw then 1hr@6kw no issues.
There are a few threads that list all the manuals, fluids/filters, etc that would be helpful.
CallMeColt
1,633
I have been spying those threads for a while. :) Joined to share my step-by-step videos. First ones should be up by tomorrow.
CallMeColt
1,633
What kind of parts and repairs did it need?
Fuel level sending unit, top fuel tank well nut, & the double float switch for the auxiliary fuel pump & low level shut off.
I thought I was also going to need to do a thermostat, but that wasn't the case..... the coolant was a bit low & I think a large air bubble was in there. Topped it off, shook my trailer & it burped.... added more. No more high temp shutdown.
CallMeColt
1,633
CallMeColt
1,633
I received my auxiliary fuel hose yesterday. Got one new for under $50. Going to add a pickup line to the 50 gallon fuel tank on my truck so when I bring it out to my off-grid place, I can hook into that fuel source & run for days & not worry.
The auxiliary fuel setup is easy to use, but I may make a video on it as well. Before I got mine, I searched & didn't find much on it.
I also ordered a few things for mounting it to an aluminum trailer that I picked up. Once I start on that, I will share as well.
