Help Identify this Gator bed
Ras1
Rockford, illinois
Hi, I need help identifying this gator bed. Is it an A3? or A2? has 2 black metal "locks" that I think hold the tailgate flat when folded down.
Also, once it is identified, I need a picture of how the hinge mounts to the frame, and where the hoist cyl. attaches, as both appear to be different than an m gator or m gator a1.
Thanks!
Dave
nickd
Newport, Delaware
It looks different than mine. Mine has a square tubular bracket that pivots out horizontally supporting the tailgate from underneath. The hinges to mount the tailgate to the frame are under the bed even with the the tailgate. On the underside of the bed you will find a bracket with a hole in it where the end of the piston attaches to the bed. There is a corresponding bracket for the other end of the piston on the frame.
wheelspinner
1,538
North Carolina - FINALLY !
Mine is exactly as you describe.
