Bisdale
- 0
- 1
- Sacramento/California
I've posted about my poor ol' gear box in my introductory thread, but I'm going to make this thread to follow my part hounding and rebuild process.
I bought my Deuce about a year and change ago and haven't done anything to it (for lack of time) since then. I've recently started overhauling all the little things that aren't quite right along with changing fluids.
The time came to pop open the spicer and replace the gear oil with some 30w non detergent. After having some trouble taking the drain plug out (it was so tight it almost stripped and i was considering welding a bolt to it) one morning i went under there and it just came right loose. I was honestly prepared for some serious sludge, but I certainly was not prepared for what I found. The oil looked pretty good for the possible 10+ years its been in there. Once it had all drained out, I stuck my finder in to test for metal shaving sediment. Oh boy golly-jee did I find me some "shavings". Not your normal fine grit, but HALF TEETH. About 17 of them to be exact. I was shocked! I had had no issues with the gear box prior to this, I was not expecting substantial internal damage.
I pulled the side cover and the top off in order to magnet stick out all the teeth and to find where they came from. To my surprise all the most dominantly visible gears were totally fine. But when I looked down to the counter shaft, I saw the carnage.
All 17 half-teeth came from what I believe to be the counter shaft 4th gear. the meshed gear seemed to be totally undamaged (very surprising to me) so I am unsure how exactly these teeth decided to chip off. These gears seem to be constantly in mesh and what engages them is the collar, but I would be entirely wrong with that assumption.
Here are some pictures:
What i believe to be the 4th gear on the counter shaft:
![20180721_121358[1].jpg 20180721_121358[1].jpg](https://www.steelsoldiers.com/data/attachments/504/504405-bcf148aceb1ff70d45d00196ef6b4ac7.jpg)
15 of the 17 chipped off teeth:
![IMG_20180721_121734_897[1].jpg IMG_20180721_121734_897[1].jpg](https://www.steelsoldiers.com/data/attachments/504/504404-9f3504dd398cb7a05a266d59332cc6d7.jpg)
The view from above:
![20180727_200504[1].jpg 20180727_200504[1].jpg](https://www.steelsoldiers.com/data/attachments/504/504394-db9d0a93c58305a194fb502b339ff619.jpg)
So here's where I need y'alls help. I'm very new to this community and I don't know where to get the parts I need. I've seen the rebuilt and non rebuilt boxes for sale from Eastern Surplus. These are an option, but I would like to explore the possibility of fixing this one and perhaps installing an overdrive kit while I'm in there.
I can't find any listings for the 4th gear on the internet, so let me know if you have one. I'm based in Sacramento and I can drive out a state or two (within a reasonable distance) to get it and help take it out of a donor or buy a whole donor gear box. I am willing to pay shipping too. I would just like to explore my options. I've heard of a "Big Mike" who is local to California who might have some parts, anyone know how I can get in contact with him?
