When I had a few engines apart I figured out how these get their vacuum. There are some passages in the head (Post #237, picture 1) that connect the tops of all the valve covers to the intake. Its that hollow dowel pin / roll sleeve that half are obscured in the photo by the springs. The valve cover continues that passage then IIRC it makes a sharp turn so the intake for that near the top point of the crankcase.
This is why the air filter plays a role in the vacuum. Basically it seems that the crankcase is under vacuum from the intake, but the passage size might prevent it from being excessive (thats a guess on my part)
You are 12 hours ahead of me. I was looking at the TM's, diagrams, and parts list to see what the sleeves and holes were and finally figured that they had something to do with the lack of vacuum as the rings are supposed to be new. I am missing one of the sleeves. Also because they did not want to buy a new gasket set, the gaskets (those that were found anaways) set on the first rebuild were used with lots and lots of RTV cement on them for the second build. Even the head gasket......go figure.
So I think I was burning oil at first, not very much, but some (blue smoke in exhaust). With a sleeve missing, that would allow the oil to enter the intake manifold and burn off. This would have a definate impact if the sleeve port was filled with oil. Also, due to the amount of RTV cement used, I have been finding ports partially filled with this crap and am wondering if the other ports are blocked as well. Time to snake the ports.
As you are 12 hours ahead of my thinking process, please provide next weeks winning lottery numbers to me. I'll share a handshake and beer with you.......
We are after all next door to each other. You in St Pete and me in Seffner (I know.....where the **** is that?). Between I-4 exits 10 and 12 just to the east of Tampa. Kingsway & US92
So it appears that the missing vacuum problem might be solved. I am going to take a piston out to verify ring status as well. Trust but verify. I trust the rings are new and installed correctly, but I am going to verify.
Thanks Demoh. I'd kiss you but I don't lean that way.........You wouldn't happen to have an extra sleeve lying around that I can gat from you?
