What have you done to your FMTV or LMTV today
mkcoen
382
Spring Branch, TX
I'd be interested on knowing how the Lizard Skin works. I tried it on a 1009 and wasn't real thrilled with the results.
Ohiobenz
274
Seville, OH
How many coats, and where all did you shoot it?
My plan is cab doors next, the whole back of the cab. Then if I have any of the 2 gal left over, a second coat in the engine area.
I'll topcoat the inner fender areas with either a bedliner or their ceramic Lizard Skin for road debris abrasion.
mkcoen
382
Spring Branch, TX
I just did the floor (front and back) with 2 coats. To be fair the 1009 is a giant tin can so sound and heat radiate off it pretty good. AND I'm in TX so heat is around more of the year than your part of the country.
Duckworthe
23
San Diego, Ca
I built a new trailer for the camper. It was a flatbed that I put sides on. I had to extend the tongue a couple feet to clear the rear bike rack on the camper while going the through very rough terrain.
Ohiobenz
274
Seville, OH
When I lifted the floor mat today the original sound/heat insulation was flaking off the engine cover hump on the passenger side. Probably exhaust heat from the turbo etc.
coachgeo
3,546
North of Cincy OH
Update... more done to intermediate axle to prep for installing in A0 LMTV. In spirit of keeping the axle fab being done all in one post .... edited the update into my "axle post" before the post gets locked. Update added into this- What have you done to your FMTV thread; Not sure how long you have before posts get locked in here.
anyway..... for clarity.... no welding will need to be done to this cast axle housing for this modification to be done they way we are doing it.
update was inserted below videos located in post https://www.steelsoldiers.com/showt...r-LMTV-today&p=2151280&viewfull=1#post2151280
tennmogger
556
Greenback, TN
Just did a grease job, but have found a neat device that made the job SO much easier. There's a lock-on grease coupler, LockNlube, that grabs on to the Zerk and won't let go. Even the tough spring pivot fittings were easy to do.
I always hated to do a grease job because I don't have three hands. You know what I mean.. Now I only need two!
https://locknlube.com/
wandering neurons
137
Fallon, NV
Work over the last few weeks
Coworker and I built wooden trays to fit the under bed storage compartments. I don’t have rails or seats, so these will be used for long cargo that won’t fit in the cab but don’t want exposed in the bed. Need to put pulls on the trays and hasps for padlocks on the boxes.
Then spent a few hours with a welder to fit a 2” receiver to the back of the truck. It’s not removable but I’m not too worried about dragging it either. I may shorten it and re-drill the holes then repaint. And need a DEEP drop to hook up my utility trailer. But the tow bar works and I can flat tow the Zombie Truck
wandering neurons
137
Fallon, NV
BTW, the white sail-looking thing in the bed is a cover over my davit crane. Universal bolt-in crane that is attached to a custom T-shaped post that I can move to any of the in-bed corner pockets. Poor mans LMHC. 1000lbs at 48”. Handy for loading and unloading tires and other heavy stuff.
Ohiobenz
274
Seville, OH
98 LMTV Cab soundproofing
Stripping the cab, powerwashed inside and drip dried in prep for inside Lizard Skin and new paint and panels...
Pulling the heater next.
Ohiobenz
274
Seville, OH
Ready to scrape and Ospho.
What are these all for?
They look like the connectors on the back of the rocker switches.
Ohiobenz
274
Seville, OH
If you haven't looked under the coating on the floor, you may be surprised at how much galvanic corrosion is going on at the spot welds...
