NormB
- 115
- 63
- Hampshire, TN
Spent the day at AOR’s shop (Jeff) helping install his airlift bumper and RICO spare tire mount.
All went together with minimal “glitches” - he’d used a list of bolts/nuts/washers needed from someone else on this board and it came up short. I’d brought a “box o’ nuts and bolts” and between the stuff I had and some parts from his nearly unlimited bolt selection (he does custom work on Jeeps mostly), we got it together.
Then my truck went up on a lift, we took the tires and Centramatic wheel balancers off and balanced the tires. Rotated them in an X-pattern - trying to find the source of a tire whine (left front) so tires were balanced (despite what we’d heard about not being able to balance tires with run-flats), couple of ‘em off by as much as 12 an 9oz inside 5+ outside; put back on my truck (balancers in a box for now) and I drove home - about four miles - listening to the RIGHT rear tire whining, Left front not so much. But the balancing is amazing.
In the process we figured out that TWO of the wheels are bent/off-center, and those tires wobble a LOT, so next job will be to replace the wheels, go through this again sometime real soon.
Fun time.
Fun time.
