PegLegFury
- 0
- 0
- San Diego, CA
So I brought home an m1009 last week. All was going fine with it so I decided to do the Doghead mod as a preventative maintenance thing(had done it on my last CUCV) and while my bud was buttoning it up there was a load pop, followed by yelling and him cursing.
So he had done a test run and had the new relay wired up, mounted on the bracket and covered in electrical tape glue just sitting on the floorboard. Turned the key and it started. Well, he/we forgot to undo the batteries again and he went to mount it back under the dash when the connectors must have touched something and it sparked.
![Good Job :goodjob: :goodjob:](https://www.steelsoldiers.com/images/smilies/goodjob.gif)
Now the 24v system still seems to be mostly working. I have 24v to the glowplug solenoid still as well has gen lights on the dash but
Turning the key gets a click from the relay but no crank.
12v is screwy too. Wipers and heater blower work as well as the signals in the front and taillights but
Dash lights are out including signal indicators, speedo, fuel, seatbelt etc. and no head or tail lights at all.
Fuse box fuses are solid and Service light switch is set to on
In essence it wont start and has little 12v power.
Ive scanned through the TM's and cant find a common connection and search brings up a lot of issues but haven't found my particular problem.
I did replace the starter with one I had lying around and did replace the 'sparked' relay with a new one.
I've squeezed the fusible links and they seemed fine but maybe I'm not seeing the one I need.
Grounds should be good since there wasn't an issue before.
Anyway, what else can I check or where exactly should I be looking for a fusible link to these systems.
PS my bud is on a strict no wire policy for the rest of this build.![Mad :x :x](https://www.steelsoldiers.com/images/smilies/icon_mad.gif)
