smokem joe
- 67
- 28
- Green OH
So I finally found the truck I have been looking for. It was in state so no jumping through out of state inspection to deal with. I had it trucked home as I was afraid to drive it in it's current condition. It has had 0 maintenance the last 3 years at least. 21K miles with rebuild out of Blount Island done at 16K. Very little blowby and in pretty good shape. I've downloaded the TMs and have been reading them. I have some issues that I'm hoping some can help me out with as I read through the TMs
Throttle was sticking badly. Stuck wherever you pushed it to. I have that freed up and working nicely and got the idle back down to 625 or so. It did idle around 900. The ball on the end of the throttle linkage was hitting the cable for the transmission and holding open the throttle. Sitting by the shop it gets twisted up some. As the frame and body twist rpm goes up slightly as more pressure is put on the linkage. Is this normal and to be expected?
The bolt on the attached picture behind shut down solenoid was loose and from the looks of the oil all over the power steering and front diff has been leaking for awhile. I tightened this down. Hopefully that stops that leak. What is this bolt for?
Both air lines going to front brakes are shot. I'd be afraid to drive this down the road as bad as they are. The lines from frame to brake can in the springs are fine. Both unprotected lines are shot. Anyone have a part number and a source? I'd like to replace them asap as I'm still reading TMs so they don't blow out while moving around the property. The rest of the air lines look to be in pretty good shape.
I can smell antifreeze while it is running slightly. I can't find anywhere it is leaking though. Anyplace common for this?
Parking brake wouldn't hold anything. Followed TM and adjusted that. I'm not sure why the spring brakes were not holding it though. I would have expected them to hold even if the drum didn't.
Other than changing the fluids and filter and giving it some much needed grease anything else I should look out for right away?
