- 542
- 381
- 63
- Jupiter/FL
Thanks, I'll use this info when I try it.![Thumbs up :thumbsup: 👍](https://cdn.jsdelivr.net/gh/joypixels/emoji-assets@5.0/png/64/1f44d.png)
Where did you purchase your bung and Inlet tube for your tank setup?The bung adapter will have to have a tube screwed into the bottom that is submerged in fuel.
You need to monitor and make sure the tank float shuts the auxiliary pump off when it gets full. Pump the tank down until the auxiliary pump will run and connect to the external fuel supply. It should refill the tank and shut the auxiliary pump off so the tank doesn't over flow. I have never had a problem with mine but I have read where others have.
My bung adapter came with my unit. The tube is 3/8" od aluminum I threaded 1/4 npt on one end.Where did you purchase your bung and Inlet tube for your tank setup?
Sent from my SAMSUNG-SGH-I317 using Tapatalk
Looks right.is this the same type bung fuel adapter?![]()
Anyone here have a good recommendation for a fuel water separator to hang on 55 gallon drum for added protection?
Thank you,
I bought one at tractor supplyAnyone here have a good recommendation for a fuel water separator to hang on 55 gallon drum for added protection?
Thank you,
I got one of theseAnyone here have a good recommendation for a fuel water separator to hang on 55 gallon drum for added protection? Thank you, Sent from my SAMSUNG-SGH-I317 using Tapatalk
