- 1,818
- 952
- Paris KY
Update - Got the new GEP vented fuel pump mounted and fabricated/installed a new fuel line; installed the coolant bypass hose and fittings; had my original 1984 Delco starter completely rebuilt and installed, along with the correct starter bracket - hot-wired 24-volt from my truck to test the bendix and check gear clearance. It was perfect; Received/installed the new ARB flexplate bolts (thanks again Ken). Next, I will mount the torque converter in the Bowtie 700R4 and install the transmission to the engine. Here are a few photos -
