In a hurry...I would make sure the cylinders are clear of any fluids. Keep the glow plugs out ?? After a good clean up, all back together, full of oil and a little in the cylinders, Spin it up a few more times and see if you get oil pressure. (plugs still out) Might be a good time to run a compression test too. Last I read injector pump sounded like it too took a swim too. Hows the PCB. Has in been drained of water? Double check that system for proper on / off cycle times or could be a waste of plugs. Fuel system... did somebody say fuel system? I have my fingers crossed on this first time start.
Ready,set, it's kind of a crap shoot, stand back and contact!! Good luck,
CAMO
