Well, I guess I don't need to post a link to my channel for you then.��
I'm still collecting parts for the Cummins conversion. No idea how long it will take me.
The LDS465-1A originally had a different camshaft allowing more lift and duration, higher ratio intake rocker arms, pistons with more compression rings, two piston coolers per cylinder instead of one, different springs in both the governor and advance units of the injection pump, and a hydraulic head with modified spill port size and angle to change injection timing and duration, plus a slightly larger delivery valve, resulting in more fuel delivered in a slightly longer spurt. This is also aided by higher spill port pressure (60-90psi as opposed to 30-45) provided by the upgraded boost pump that comes on the LDS pump.
