- 4,736
- 1,115
- Gaithersburg, MD
Or, your differentials are pressurizing and causing differential lube to seep out. Open the fill plugs slowly and carefully and listen to see if you hear an air release sound.
Fording plug. You only install when entering high water. leave it out to prevent buildup of crap inside of it like clutch material or oil.So after the rain let up I crawled underneath and found it's not diff fluid.Its It's the throttle body or the fuel distribution control. Its leaking fuel just a tiny drop at a time. See photo added. Also why is my transmission missing this plug? I can see the clutch spinning. Also see photo. Thanks guys
Disregard, saw the other posts addressing the vents.I need some help here. My 813A1 has lubricates coated all over the front diff and slightly seeping out on the rear riffs. Is this normal or what? I'm most certain it is diff fluid.
Forgive my ignorance but this my first diesel. Can you point me in the right direction on getting new parts or NOS and a "how to" on fixing it lol.Yup, Fuel pump is leaking at the throttle shaft....most likely. Look higher on the pump, if it is wet at the plate covering the shaft and not higher, it needs a repair...the pump.
Here is a top picYup, Fuel pump is leaking at the throttle shaft....most likely. Look higher on the pump, if it is wet at the plate covering the shaft and not higher, it needs a repair...the pump.
So, I'm new here as well. Here's what I've been doing-Forgive my ignorance but this my first diesel. Can you point me in the right direction on getting new parts or NOS and a "how to" on fixing it lol.
More than likely its the throttle shaft... You can repair it on your own but it isn't much fun. You have to remove the pump and disassemble the unit. Member Technoweenie did it awhile back. Maybe he could help you. A pump shop may charge you $350 to $600 for a pump rebuild... The truck just sitting has caused the orings to just get hard and fail.Here is a top pic
If YOU are saying that rebuilding the pump is a PITA, then it's definitely not for the newb or the faint of heart. I would happily fork over around $500 for a professional rebuild if the shop was trustworthy. I'm going to guess that a whole replacement pump would run at least $1k.More than likely its the throttle shaft... You can repair it on your own but it isn't much fun. You have to remove the pump and disassemble the unit. Member Technoweenie did it awhile back. Maybe he could help you. A pump shop may charge you $350 to $600 for a pump rebuild... The truck just sitting has caused the orings to just get hard and fail.
Plus rebuilding the pump may give you some additional power to move that heavy thing.
Careful, depending on how old the "NOS" pump is, if the rubber parts inside are the old non LSD compatable stuff, you'll have the same issue you have now in short order.Got any part numbers for the pump? Cuz I found a guy locally that has a NOS for $400 or best offer
Ah, ok. This is very different than what I thought. So, if I want to use air tools driven by the truck's air system, I should plug in at the trailer service air brake fittings at the rear of the truck?The front glad hands are for when the vehicle is towed. Air lines are connected to the towing vehicle, the emergency line charges the system, the service line will operate the brakes.
Only the front emergency line has a shut off valve. The service glad hand doesn’t have a shut off valve and if it has a dummy glad hand installed it should have a vent in it. If the front service glad hand doesn’t vent the brakes won’t release properly.
