- 241
- 85
- 28
- North Augusta SC
Mine were backorderd. They showed up in about 2 weeks.
What I would do now is go to NAPA and buy some piston seals in bulk. Last time I bought some they where still made in the USA with quality material. The Chinese seals I've found fail after only a year or two. The cylinder and springs are good quality though. I bought several boxes of "bulk" seals from NAPA and the cheap Chinese wheel cylinders. Seems to be a good working combination so far.View attachment 738251View attachment 738252
Got the Raybestos WC4419 from Summit today. They are Chinese but have correct springs & pistons. Everything looks good but the copper washers, they were beat all to ****.
Just pulled the wheel cylinder off my deuce. The WC is at least 25 yrs old and has the straight spring. The cup end show a bit of corrosion from sitting, but slide nice from soaking in DOT3. Probably going to replace it since there are signs of pitting where the pistons sat. MFR: Wagner LockheedYes, there is a difference.
Look at this wheel cylinder spring:
Now look at this wheel cylinder spring:
Notice how the first (top) pictured spring has straight ends but the second (bottom) is tapered on the end?
The second (bottom) spring is what's correct and what you need and it's what the Napa 4419s have.
That tapering on the end of the spring pushes out on the wheel cylinder cups and keeps them sealed against the bore of the wheel cylinder. If you have the standard springs, the wheel cylinders won't leak but if the truck sits they'll let air in.
Rusty, I just picked up a couple of rebuild kits from NAPA this past summer, and they're marked assembled in USA. I'm going to assume that means Made in USA. Now I purchased a complete wheel cylinder from NAPA last summer and they are marked Made in China.What I would do now is go to NAPA and buy some piston seals in bulk. Last time I bought some they where still made in the USA with quality material. The Chinese seals I've found fail after only a year or two. The cylinder and springs are good quality though. I bought several boxes of "bulk" seals from NAPA and the cheap Chinese wheel cylinders. Seems to be a good working combination so far.
Unfortunately, "assembled in the USA" just means the parts have been put into a box in the USA. The parts are likely made in Asia.they're marked assembled in USA. I'm going to assume that means Made in USA. Now I purchased a complete wheel cylinder from NAPA last summer and they are marked Made in China.
Sad but true. Mine all had "Made in USA" embossed in the rubber.Unfortunately, "assembled in the USA" just means the parts have been put into a box in the USA. The parts are likely made in Asia.
Then you got the good seals !View attachment 753139 Rusty, I just unpacked my recently purchased NAPA 45 Wheel Cylinder Kit, and much to my surprise the seals have "Made in USA" embossed on the rubber. None of the other parts are marked.
