lmtv ctis wheel hose sources
jkcondrey
141
Rutherfordton, NC
I am looking at replacing one or two of the hoses on my lvad wheels. Figure 158 in parts diagram, item 27 and 18. Rubber is falling off and steel webbing is rusting. I have only found one source only for each, at a hefty $72 and $161. Anyone know of a more family friendly budget source?
Suprman
704
Stratford/Connecticut
I have the complete assemblies both new and used with the valves rebuilt. Not cheap though. You may be able to take off the wheel valve to valve stem hose and have a Parker store make one. Not sure if they would have the valve to banjo connection though.
Will
simp5782
Feo, Fuerte y Formal
9,495
Mason, TN
those prices won't do you any good really with a lead time on the one of 58 days and the other is 106 days to have them made since spicer does not stock it anywhere in the country.
I have several totes full of take off valves with hoses.
Third From Texas
6,646
Corpus Christi Texas
Have you tried a local hydraulic/pneumatic repair shop (one that makes hoses)?
I've got two spare in the same condition (rubber has rotted and the steel braid has rusted up). I'm just going to take one to a couple shops. Pretty much standard hose (same exact hose on my off-road shocks that run to the the reserve canisters) and standard fittings. Only thing you need is the banjo fitting on the one end (and those can be found online or at NAPA last I heard).
Brand new should be a ton cheaper than surplus (funny how that works sometimes). I mean unless you just must have actual OEM milspec (that someone made up the same way at one point).
If I get out to the shops next week I'll post what they quote me. And I'll see if I can find the link to those banjo bolts.
