- 602
- 13
- 18
- Hereford Arizona
![IMG_20190315_144954.jpg IMG_20190315_144954.jpg](https://www.steelsoldiers.com/data/attachments/520/520095-6b57b933e2ee8579c63d79c49cca7747.jpg)
I also drilled out the old pins and replaced them with bolts, found some grade 8 ones that had enough smooth shaft to clear the hinges and tightened the lock nut all the way down and cut off all but 2.5 threads past the nut. Looks a little shaky but it won't rust anymore and will last longer I think.
