- 958
- 1,371
- 93
- Wilson County, Texas
I knew about the temperature formula & tried to use it but my temp was less than 10deg from the 77deg in the TM. I think my high readings were just from my meters not being super high end.An open stator winding would read infinite ohms in a pair of it were burned open and much lower if it were shorted.
Don't forget, the readings in that table are "temperature" dependent, they are not cut and dried for all conditions.
You might try pulling off the stator cover end and look at the visible windings for any indication of over heating.
I found indications of overhearing in one of my sets and am in the process of changing the stator.
I did check the stator & that's how I found the broken wire. It looked very clean.
![57133833_2237156473212450_795178680497209344_n.jpg 57133833_2237156473212450_795178680497209344_n.jpg](https://www.steelsoldiers.com/data/attachments/522/522417-9b890dd778338e57c28d279bde5f8e10.jpg)
