My advice would be to stay off the road with those tires. They really look great and they perform well in the dirt, but they are literally a time bomb waiting to kill you.
IIRC, the 11R20 Michelin XLs are somewhat still available, unlike the "super single" XL tires we are used to seeing on 5-tons (14.00 & 16.00 sizes usually), that are old and unreliable, especially when sitting flat for any period of time which will damage the sidewalls.
I remember when the 14.00 XLs (aka "Super Singles") first were installed on USMC M923 trucks; some units reversed the tread pattern on one side of the truck before Desert Storm kicked off, so that the enemy wouldn't know if the truck was coming or going....one side the tread is pointing one way, the other side it's pointing the other way. It also allowed the tires to all be mounted the same way, allowing a spare to be used on either side. I don't recall ever hearing about any negative effects from "reversing" the tread pattern.
As for semi-truck tires, there are Steer, Drive, and Trailer positions for these...don't ever use Trailer tires in the Drive tires position! The sidewalls are stiffer on Drive tires to account for the torque required to get a loaded rig rolling; Steer tires have different tread/sidewall compounds to account for the scrubbing/scuffing of turning while stopped or at low speeds, as well as cornering while loaded. NEVER use Trailer tires for Steer/Drive positions!
