- 2,136
- 618
- Davis County, UT
Well, I sold my 1968 M101A1 and, in favor of the surge brakes, bought this 1997 Pribbs M101A3 from Gunzy!
Obviously from the stenciling it places it as a former USMC trailer. It hardly has been used too, but not surprisingly the surge shock is bad and the master cylinder was dry and rusty. It also has a slightly damaged passenger fender, but *shrug* it's not all that bad.
A little side-by side comparison of the A1 vs the A3. A few of the differences to note of the A3 over the A1
Of course, I transferred over all the goodies from my A1 to this A3 before I sold it.
LED tail lights with much more straight brackets, license plate mount, longer, zinc yellow 3/8” grade 70 safety chains, new suspension shocks, new A3 jack (sold the rustier one), and fiberglass side racks & all-steel bows. (I should have kept the military 12-pin trailer plug though, oh well, it wasn't in the best shape anyway).
Oh, and I drilled the holes up front for double end-gates for increased usability! Note: I haven't yet drilled the holes on the side rails for latching the gates open.
The 36"-39" ADCO 3950 tire covers that fit the 9.00-16 NDTs a bit loose fit the HMMWV tires a bit tight and don’t fully cover the lower tread, but they a decent fit otherwise.
- Surge brakes (just like the A2)
- 4" tall frame vs 3" (the tongue is still 3" tall though)
- Tongue jack vs kick stand
- Wider spacing between the interior wheel wells vs 45.5"
- More pronounced exterior fenders for the wider tires and slightly wider wheel base
- Reinforced cargo body by the tailgate
- Raised center portion of the axle for increased ground clearance
- Reinforced axle ends by the brake drum
- HMMWV wheels, tires (supposedly with run flats?) and 8 x 6.5" wheel bolt pattern
- Larger looped shackles
- No rear stabilizer leg
