erasedhammer
- 58
- 28
- Maryland
Yes the pump is dry. But that pump is working. There is fuel getting to the inlet of the filter. I'm probably overthinking this and its just a clogged filter. Hopefully.Loosen the flare nut on the fuel lift pump and see if it has any fuel pumping when you crank it over. is the fuel pump dry externally?
