DB556
- 129
- 43
- Ambridge, Pa
Well its like the title says, I'm going to convert my M35a2c to a long bed bobber if that is the correct term or is it just a 4x4 conversion?
I've seen a few pictures of trucks with the full size bed and the rear most axle staying about the same postion, cant seem to find any build threads.
I've saw pictures in the bobbed deuce thread and got hooked. So anybody build a long bed?
Plan is some used ~50% thread goodyear MVT 395's from eastern surplus(there cheap) on Hutchinson aluminum MRAP wheels,
I'm probably going make my adapters on the cnc mill out of some half inch Grade 50 since there seems to be problems with the latest batches of them.
I just need to find a blueprint for the adapters with the cutout for the CTIS module. Well unless I remove the CTIS unit and run a schrader valve.
I'm debating about the rear drive. Run a extra long shaft? New shafts and carrier bearing?
I'm thinking I can use the stock read drive shafts, If move the rear axle forward 12" and weld in a cross member with a carrier bearing use some splined shaft and the flanges from the extra axle.
If this is any ones truck let me know.
![maxresdefault.jpg maxresdefault.jpg](https://www.steelsoldiers.com/data/attachments/523/523228-32fe2a478c060e9007aa47d7ec21c2d6.jpg)
