- 18,059
- 27,076
- Burgkunstadt, Germany
Yes. The float has to be installed to open the Solenoid. You can also jump the pins on J33, (float switch C-Plug) or just hook up the float switch, (much easier) to the J-33 C-Plug, and move the floats up and down by hand, to get things to work. You can take the J36 C-Plug off the L2, (day tank fuel solenoid cut off valve) and move the float for refill the tank, and pin A on J-36 should have 24 VDC. If not, we need to check CR-27 diode. The black box next to the L2.
The pumps should run fast when you crack the first filter. The pumps can send fuel or air, to someplace, an outlet, when the filter is cracked. When the pumps try and pump into the day tank, and the solenoid is closed, then they can not pump fuel.
Crack the first line on the out put side of the fuel pumps. Just a bit, as the pumps can make a big mess, in a short time! Then follow the fuel system all the way to the Day tank. Crack each line/fitting. it bleeds the system, and we can see whats not working.
