Loud Hum Noise when coasting
cucvmule
collector of stuff
1,149
585
Crystal City Mo
Dana 70 pinion bearing preload 20-40 inch pounds new
pinion nut torque 220-280 ft.lbs
If you are, should use new pinion nut go ahead and use blue Loctite anyway.
And after a heat cycle put on gloves and grab pinion and see if there is any movement in the bearing. You may have caught it in time.
For some reason I can not see your video so I can't comment any more.
erasedhammer
58
Maryland
Does the Dana 70 use shims or crush sleeve? Saw on another forum someone said Dana 70 uses shims
Chaski
55
Burney/CA
So - Are you somehow uncertain if you replaced a crush sleeve?
I thought the only 1028s that had the Dana 70 were the dually ones.
cucvmule
collector of stuff
1,149
585
Crystal City Mo
For the 1028A2 HD70 Dana Has pinion depth shim pack and pre load shim pack.
For 1028 Corporate 14 crush sleeve,or solid spacer with shims to set pre load. If pinion bearing is bad then damage occurs Quickly as Chaski has warned.
Heat is the big killer of axle assemblies, especially the pinion bearing when gear oil starts to be either lost, no lubricant, or breakdown of the gear oil, from heat , cooking it. The pinion is what usually goes first, from preload becoming no load.
erasedhammer
58
Maryland
My truck is a dually but just running single wheels.
I think I caught it. Only drove about 4 miles with it before the seal started leaking.
