cucvmule
collector of stuff
- 1,165
- 597
- 113
- Crystal City Mo
Dana 70 pinion bearing preload 20-40 inch pounds new
pinion nut torque 220-280 ft.lbs
If you are, should use new pinion nut go ahead and use blue Loctite anyway.
And after a heat cycle put on gloves and grab pinion and see if there is any movement in the bearing. You may have caught it in time.
For some reason I can not see your video so I can't comment any more.
