2INSANE
- 847
- 93
- Belgrade, Montana
Hello! I bought a custom built DB2 IP from Badgerdiesel eBay because the old ip was leaking from the throttle seal. I installed the new ip and the M1009 fired right up but ran rough with white smoke with the ip timing set mark to mark. I advanced the timing as far as I could and it runs a lot better but still smokes a little and runs a tad choppy when cold.
My question is what would cause the ip to make it run better when advancing it all the way? I should not have to advance it soooo much right?
it has new injectors, new lift pump, new Gear drive.
Should I try and up the fuel on the ip?
