Filter Help M35A3
skidunits4you
Washington NC
Anyone have the filter numbers for NAPA replacements for Oil and Air filters on the CAT engine I can't read the numbers on the filters on truck someone painted them. Thank you
papercu
31
Baxley, Ga.
The engine is a 3116 ATAAC Cat. couldn't you just ask them? I show the oil filter as a Cat number 1R0658 or a Baldwin B76. Fuel filter as Cat. number 7E9763 Wayne
skidunits4you
Washington NC
I called the local CAT dealer and got if you dont have the set up number I cant help you. That is why I asked here. Thank you for all the help
papercu
31
Baxley, Ga.
What is a set up number? I call the local NAPA and using the cat part number I have this.
Oil filter NAPA number 1791 price 10.68
Fuel filter NAPA number 3239 price 8.68
Your mileage may vary. Wayne
skidunits4you
Washington NC
Thank you all I picked them up and changed them tonight. Yea that was my question for CAT too the guy wanted the serial number of the motor to kno wthe set up number never had so much problem from them to get filters. ( I didnt tell them I was buying them from NAPA) The state has a parts contract with NAPA so NAPA it is. they seem to work well on most of our other MVs. Again THANK YOU
lonegunman
Eastern, Washington
Looking at my paperwork from Cat, they have two filters listed with Cat part numbers but do not say which is fuel and which is oil.
They are,
Filter_________ 3239 _______________ $13.22
Filter AS_______1R-0739_____________ $10.90
The trans filter kit had part number 29540976, which might be the Allison number for the internal filter for the 1545. It took a Baldwin spin on as well, BT 230.
Hope this helps.
Havasu Sun
Austin/TX
For those who have switched to ATF for the tranny... What external filter did you use? Does the filter that it came from the army with, which is an oil filter also work with ATF fluid?
Thanks
porkysplace
1,494
mid- michigan
The part numbers are bin the deuce parts spreadsheet ( at the bottom ) in the stickies of the deuce forum
HDN
5,136
Finger Lakes Region, NY
I was told to used oil only in tranny
While oil seems to work fine for my M35A3's transmission, I still plan on switching to Dexron III ATF in the springtime. The main reason I've heard that using motor oil in the transmission is problematic is because it eats at the inner seals. The seals were designed to work with ATF, not motor oil.
