- 123
- 2
- 18
- Washington NC
Anyone have the filter numbers for NAPA replacements for Oil and Air filters on the CAT engine I can't read the numbers on the filters on truck someone painted them. Thank you
I was told to used oil only in trannyFor those who have switched to ATF for the tranny... What external filter did you use? Does the filter that it came from the army with, which is an oil filter also work with ATF fluid?
Thanks
While oil seems to work fine for my M35A3's transmission, I still plan on switching to Dexron III ATF in the springtime. The main reason I've heard that using motor oil in the transmission is problematic is because it eats at the inner seals. The seals were designed to work with ATF, not motor oil.I was told to used oil only in tranny
