sermis
- 17
- 38
- Temple, TX
This has been a challenge workout the MWO 9-2320-289-35-5 (if someone has it let me know).
The AC kit is 4130-01-503-9310 which has new grills, lines, O rings, compressor, etc. I know RAPCO has the kits so if you are trying to make a M997 this is a good start to get it right. Finally discovered the two small brackets in the kit is all that is needed to mount the pancake compressor. Belt is the inboard grove and replaces the power steering belt. Other than guessing what goes where its fairly simple. Only question now is where the AC lines go through the tunnel.
Sent from my SM-G920V using Tapatalk
