So, there are two studs in the photo and one of them is broken off, that's the one that the power steering pump pivots on. Now that I think about it though, I'm not sure at all what the other stud is attached to. I know I didn't take anything of it yesterday during disassembly.I have them brand new. They are the same M10 x 1.5 metric stud/bolt that are on the intake manifold. Send me your address and I will send you one. Or remove one from the intake manifold and replace it with an M10 X 1.5 bolt of the appropriate length. Good Luck. Let me know. To be honest. I would just go to the hardware store and pick up a die. I would run it over that stud put a new M10 x 1.5 flange nut on that stud and call it fixed. It only acts as a pivot point for the Power Steering bracket. It was left loose for a while. Good Luck. You can do it. View attachment 788367View attachment 788368
I do not have a lower bracket. I was planning to look into that more after I get it back together.Looks have no bearing on the usefulness and the functionality of a specific part. If it works hold the belt tight and allows you to stay mobile is all that matters. You do have the lower bracket in place? Just checking. Good Luck.
I have number 10, so I need to track down or build number 9. One of my next projects is going to be upgrading my CJ from the 4.2L with vbelts to a 4.0 with serpentine belts, Im thinking I can build part number 9 out of the power steering pump bracket I take off of the Jeep.The lower bracket missing is the root of most broken cracked Power Steering brackets. I made a few of the #10 part. And I have a few of the # 9 part. Without these brackets holding that main bracket steady it is just a matter of time before the main bracket fails again. If it is a vehicle you want to depend on. Now is the time to fix it right. Again flat bar and an M10 flange nut. Form and weld the flange nut in place. Good Luck. A 6.2 is only .3 liters smaller. The difference is in the bore, and in that, the block isn't 'hogged out' as much around the main web areas. More meat in between the cylinders too. Heads are slightly different, be can be used with all 6.5 peripherals no problem. 6.2 heads have bigger valves and have the potential of flowing lots of air with some work. Be Safe.
Yeah, I'm not a great welder and neither are the other people who have fixed this o.oGEEEEEEZZZUUUUSSSKKKRRRIIIISSSTTT!!!
I wish I could un-see that.
