- 8,648
- 3,006
- Monrovia, Ca.
The museum also owns an M114. The data plate nomenclature says T114. The t114 variant was the tank Killer, had a 106 recoilless mounted at the Commander's Coppola. There weren't too many made, I think it was experimental. This particular track has US Air Force markings. It is marked TRTG, tactical radar threat generator. The hull has been cut on the right side to accommodate a big generator. The generator is no longer in the vehicle but the control panel is. It was capable of 120/208/240 in 60 AND 400hz. The rear Gunners hatch and gun mount have been removed and welded over. The driver's hatch has had all of the vision block holes plugged and welded shut. The Commander's Coppola should be a clam shell type with a weapons mount. That hatches gone and covered with aluminum. One of the vision blocks has been removed and a whole bored vertically through the top of the vision block and into where the Coppola would be. I have no idea what was there. There's also amount on the front glacis plate where the swim board would be that held a radar dish. My job is to make it run. It hasn't run since 2001. So far looks like it just needs a carburetor repair. It cranks but no fuel.
