Our CTIS system are not really compatible with 3.07 gears
Reworked LMTV
1,571
1,217
TN
I just realized something. Correct me if I am wrong. If you run high speed gears, in order to run at the maximum Goodyear MV/T speed (I have seen 65 and 68 mph ratings for max. speed), you have to be running 120 psi in tires (per Goodyear document). I don't think our CTIS systems run that high, unless modified. Makes sense, since higher pressure would reduce the heat. Would likely make for better handling and less wobbly side walls at higher speeds.
Anyone with 3.07's running 120 psi?
coachgeo
3,547
North of Cincy OH
Poor memory says my Mvt tires say 100psi max on the side of them. Am running 90psi
Reworked LMTV
1,571
1,217
TN
You are probably right. I will double check. When I get home I will get that Goodyear documentation that I found that mentioned the 120 psi.
Ronmar
8,356
Port angeles wa
weldergq692000
Isaac2017
I just updated my transducer yesterday. It took less than 20 minutes for my tire pressure to adjust to 80 psi when the light stopped blinking on the controller. I did look in the old transducer and noticed a lot of crud which I took as the result of failure to the system.
wheelspinner
1,539
North Carolina - FINALLY !
Also remember that those ratings are based on a FULLY LOADED tire. Running empty trucks around wouldn’t even come close to maxing out a tire.
Third From Texas
6,669
Corpus Christi Texas
This is one of the easiest mods to do and saves a TON of wear on your tires.
coachgeo
3,547
North of Cincy OH
Also remember that those ratings are based on a FULLY LOADED tire. Running empty trucks around wouldn’t even come close to making out a tire.
We've all been desperate before...... but hope most in here will ever got to the point to of "making out (with) a tire"..... so I'm guessing you intended to mean something else when you wrote the above.
Berend
73
Albany GA
On the A1 trucks it's really easy to reprogram the CTIS controller and change only the High way setting for example. You can also reprogram the CTIS over-speed warning or turn it off completely. But you need to have the diagnostic tool for that.CTIS.jpg
fuzzytoaster
3,714
Fort Worth, Texas
What plug/cable are you using? Any pics?
