Reworked LMTV
- 1,158
- TN
I just realized something. Correct me if I am wrong. If you run high speed gears, in order to run at the maximum Goodyear MV/T speed (I have seen 65 and 68 mph ratings for max. speed), you have to be running 120 psi in tires (per Goodyear document). I don't think our CTIS systems run that high, unless modified. Makes sense, since higher pressure would reduce the heat. Would likely make for better handling and less wobbly side walls at higher speeds.
Anyone with 3.07's running 120 psi?
