Deuce hood fixing
Privatewrench
19
Kentucky
I'm getting ready to repair my hood. It's not in too bad of shape, just has some warping and dents. Doesn't lay completely even from one side to the other. Looking at the support beams under the hood, it seems like the beams are bent. Like the hood was walked on and bent towards the engine. The gap from the beam to the hood is about 1 1/2", so not too bad, but could be causing my warping. How are your support beams on your trucks? Should the hood metal be flat against the beams, or is the gap normal (new normal).
Thanks
ldmack3
1,740
N. Central Idaho
Thanks
I'm diving into repairing my hood. Several cracks and big gap between hood and support beam.
How did yours turn out? If you don't mind my asking what did you do? I'm planning on adding reinforcement to both sides and the beams.
