WildernessJeep
- 89
- 28
- Huntsville, Texas
The 4th guage is the volt meter. As for the source of them, the parts manual will give you the manufacture and part number. The ones on my 2 sets are pretty inaccurate so after market might be better. There was a mwo to change the rear tires from dual ndt's to singles.
No, it did not come with duels. That's the way it was made. You will need more then lug nuts and thimbles. The axle is different also.So do you think it came with duals tires and was later changed to singles, or was this trailer always a single tire axle? I'd prefer the duals, if it would be as easy as buying two more rims. I want to load it down with fuel, and don't want to overload the tires.
R
Would also suggest you down load the TM's, if you haven't already. Most of the gauges should be available, if you look for them by part number and NSN.
