I'm trying to get accurate air Intake Specs for the Cat 3126 of a 1999 M1083A1 so I could convert it to Donaldson air filters.
I'm hard headed and don't want to just copy what others did without ensuring proper specs.
I've been trying to find this engine intake CFM specs and so far I could only find info on the Marine version.
https://barringtondieselclub.co.za/caterpillar/3114-3116-3126/cat-3126-spec-sheet-abby.pdf
The documents from Donaldson themselves don't seem to be accurate. I wanted to get specs from Caterpillar.
https://powertherm.com/PT2/images/PDF/DonaldsonAirFiltration251-258.pdf full version here: https://www.donaldson.com/content/d...0027-ENG/Air-Intake-Systems-Product-Guide.pdf
Donaldson doc says it can take up to 1355CFM @190HP 2200@PM, while on the 3116 it's only 618 @200HP 2600RPM
Even donaldson says: "Ideal Method Obtain from Engine Manufacturer. For the most accurate engine airflow specifications, Donaldson recommends using the intake airflow rate specified by the engine manufacturer "
