street legal humvees
- 0
- 1
- punta gorda ,fl
hello ! we just took in a m998 an 86 but had a recent gep swap looks like somebody rebuilt the injector pump as well we have limited knowledge of the trucks history / the truck starts and runs fine idles fine but under load w acceleration it iot bogs way down and will essentially not pick up acceleration after a few seconds with foot on accelerator it will rapidly pick up acceleration and appear to run ok once you back off pedal does same thing again
we drained fuel and changed the filter its getting good stream at the stopcock and we did crack most of injectors seems to be getting good fuel to the injectors.
tried to sorta do the old hand time with a 2 x 4 without any luck but don't have precision timing equip available . question is any thoughts? think timing may be culprit ? or any other ideas
second part of question while messing w this issue we noted we had i couple pull off injector pumps at the shop just not sure if they came off a 6.2 or 6.5l to be honest i know the 6.2l stanadyne is the db2 2829 4879 are there other brands or part numbers that were used ? is this the only 6.2l pump ie if ones in shop (am checking in am) are of a different number then they are 6.5l any help much appreciated
