MEP-802/3 noco charger placement
Sgt Jiggins
Potato Peeler
291
NorCal
Hi All,
Somewhere on here I came across a thread where someone mounted a noco gen2m inside their MEP-802/3. Of course the great google isn't being of much assistance on this matter.
So, before I reinvent the wheel, I thought I'd ask a couple/few questions:
Where have other seen fit to mount one?
Any issues with operational oscillations leading to it causing a racket?
I wondered about putting it here (see image) and wondered if anyone else had?
Cheers,
SJ/JD
Light in the Dark
6,750
MA
I mounted mine on the inside of the dead crank door... is that what you are thinking of? I didnt get any extra noise from where I put it. On the machine I mounted it, your proposed position had the arctic heater kit installed (but I have since sold that machine, but retained the NOCO). It might fit there, I haven't checked.
I also looked at putting it same post, but other side... behind where the CT is. I'd have to look at the length of the wires again, but it might even be able to be mounted on the upper right back of the machine (which is where I put my wiring diagram, after moving it from the door) and just use a Heyco panel strain relief or similar to have a water tight entry point back into your machine, for the leads to pass through.
Sgt Jiggins
Potato Peeler
291
NorCal
LitD, I kinda figured you'd be first on this one. :)
Guess I could put it on the inside of the door now that you mention it. I had thought an interior wall might be better to keep it more out of the way. My hesitation was not knowing what on the other side of where that pic has the red box. Been wanting a scope, maybe it's time to get one!
Light in the Dark
6,750
MA
I am currently working from home due to the world's events... so doing my part in whoring up SS.
Taking the roof off would be imperative in mounting on the backside of that firewall... there are many components back there. It can absolutely be done with care and patience. I would think the CT side would be better, as its spaced off (so you have room to put fasteners on the other side), but with enough ingenuity you could put it anywhere you want.
Sgt Jiggins
Potato Peeler
291
NorCal
Welcome to the whoring, I mean party! I've seen others say it already, but yea, Covid has been Great for the heavy green metal projects in life. Thanks for your help with this! SJ
