- 6,719
- 14,363
- Hawthorne, NV.
It's United Technologies. I think they made the injectors on my multi-fuel.I don't know, but I can go look. Is there
Here it is! Looks like a UNN Technologies?
Did you look at the first two pictures on the thread removing the Head from a G pump. You will see at the base of the head and IP housing a bolt looking thing on his and no FDC. I will just say on yours I saw a FDC and a quick look at your pump did not have that bolt head thingy. On the G pumps that is an oil filter and oil is suppled to the Head on G models and it runs into the Head. Trying to remove the Head will damage the oil feed / oil filter and maybe the Head. Remove all clips that tie the injector lines together. Remove fuel line to Head. Remove injector lines. Remove fuel control unit assembly. Line up the red / scribe mark on the Head pointer and remove the hold down nuts. Head might need a little I said a little tap with a plastic hammer and it will pull out. Look at the pictures if nothing else. I do believe you do not have the G pump so you are good there but check to make sure I am right always. Did I forget anything?
