LMTV 4-Pin Electrical Connectors
jmumme
Woodinville, WA
In taking apart the LMTV cab, I found the Heater plug had melted. Was wondering if anyone knew where to purchase the 4-pin rubber electrical connectors? I find a lot of the single pin packard fittings, but not the 4 pin. Here are some pictures of the fitting. One is of the melted fitting, the other two are from behind the dash gauge panel and I believe are the same connector. Any help is appreciated! Thanks!IMG_0795 (1).jpgIMG_0794 (1).jpgIMG_0793 (1).jpg
Third From Texas
6,460
Corpus Christi Texas
Now would be a great time to cut out the military connector and replace it with a civilian 4-wire plug.
Pros:
1) Less expensive
2) Easily acquired
Cons:
1) May not come in military green
2) No fun to hoard
3) Cannot resell for 500% markup
jmumme
Woodinville, WA
Pros:
1) Less expensive
2) Easily acquired
Cons:
2) No fun to hoard
Haha, Yes, more than likely going with a civilian Deutsch connector as a plan B.
