GlassJoe
- 0
- 1
- Lake Norman, North Carolina
Who has the best price on Packard connectors?
Thanks
Thanks
Thanks
Does Erics ship pretty fast?Erik's.
I'll second this. Lube makes life so much easier if you plan on connecting more than once in a lifetime.When you slide the male into the female I recommend putting a little dielectric grease on the male. It helps them slide together easily and helps prevent them from getting stuck in the future.
The problem isn't Erik, the problem is that shipping is totally out of whack during the pandemic. But yeah, he normally ships promptly.Does Erics ship pretty fast?
Thank you for the tip Flyingvan911.When you slide the male into the female I recommend putting a little dielectric grease on the male. It helps them slide together easily and helps prevent them from getting stuck in the future.
The TM states for field repairs... just put some spit on it, CAMOWhen you slide the male into the female I recommend putting a little dielectric grease on the male. It helps them slide together easily and helps prevent them from getting stuck in the future.
