Dasgog
- 151
- 43
- Tucson, AZ
Hello
From the neutral setting I find it pretty stiff to push the lever into High Gears but it does go. Back to neutral and from neutral to low is buttery smooth.
Is there a grease fitting for this down below or is this not uncommon? The vehicle runs and performs as should it’s simply the rough /resistive force when pushing lever from neutral to High.
Any suggestions?
Transfer Case, Trans fluids have been changed as well and are full.
Any suggestions?
