MEP 802A Fix-up Thread
CallMeColt
1,633
Wilson County, Texas
So, I found some of the padding that is used as a sound damper in the dumpster while at work. It was in all kinds of strange cuts, but I took what I could from it & placed it around the generator. Not sure if it will make a difference at all, but it won't hurt anything. Made a small holder for my logbook for maintenance as well. Hopefully, more will pop up so I can finish it off. Ashamed how wasteful the military is. The stuff I find in there...
99424097_283830466340736_8843222492915957760_n.jpg 98551335_1001797876890009_8192125641483616256_n.jpg 98201570_3109193745807866_6248662058259185664_n.jpg 99117444_722641218507182_2162327106514583552_n.jpg 97999213_885160551957417_1992342694759759872_n.jpg
CallMeColt
1,633
I'm at 402 hours & really have not had issues. :)
A small crack at the muffler flange has popped up but that is an easy fix.
Still a real slight oil leak that I can't quite pinpoint. I changed the oil last month & it wasn't really down at all so for a 26 year old generator, I'm not going to complain. Did toss some stop-leak stuff in there to see if it will help.
A few broken wire connectors right inside the doors but easy, in the field fixes.
Very happy this project has finally just gotten to the point where I use it & just change the fluids. :)
CallMeColt
1,633
So, I got my hands on a LPW2 motor that was being scrapped to take some parts off of. I took a little bit of time & made a video explaining the injetion pump installation & removal.
I previously was a bit confused on this & saw that many others on the forum were as well. Since I'm more of a visual, hand on person, I thought a video showing what was figured out a few times would be helpful. The TM does explain this, but sometimes that can be more confusing & doesn't always tell you why it needs to be done.
Hopefully this is helpful to some people moving forward!
wheelspinner
1,538
North Carolina - FINALLY !
Holy crap! It all makes sense now!!!! Thanks !
CallMeColt
1,633
It's been a while, but a problem popped up.
191214371_309631770754778_4915403636622856326_n.jpg 186004977_826798664617685_3048189191770950959_n.jpg
The mounting tab on the generator head broke that is on the output power lugs side!
For the longest time, I could hear a clunky type vibration noise but could never figure it out. Must have been this before it completely failed.
Noticed the engine moving more than usual when doing a test load. Made me start to look around & I noticed it. Hard spot to see.
Not really sure how I am going to fix it. Thinking I will remove all the side panels (oh fun) & then get some sheet steel about as thick as what was there to wedge under & bolt down. Then, give it a few tack welds. Remove the rubber mount & finish welding. All while making sure there is a VERY good ground.
Anyone else find one of these broken?
CallMeColt
1,633
I never, ever, saw such a failure.
I'm good at doing things for the first time!
Here's my guess on how it happened...
Over the years, water made its way in & it ended up settling out in the mount there making it weak.
I got it & mounted it on the trailer. When I tow it, I do a lot of off-road to get to my off grid cabin. Some of it is pretty bad after rains wash out roads & stuff.
Between that & it being used, finally gave up.
CallMeColt
1,633
Got the mount repaired over the past few days.
Spent the first day getting it all opened up. Some of these bolts are a big PITA to get at!
195371602_475857046822556_8969961975029947901_n.jpg 195718963_515751816220477_2446459950970286497_n.jpg
Drilled the 1/2in hole in a plate I had so it would make the most contact with what was left & then welded it. Not bad for my $80 harbor Freight Tools welder. For some reason, the paint made it look worse than it was... not that my welds are good anyways!
194786165_467966424506260_4074552464441931455_n.jpg 189324101_297052665403244_7603711792006304141_n.jpg
I replaced the fuel/water separator filter while I had that side off since it was much easier to do like that.
I also put some of the sound dampening material in the vent area as well as on the inside wall since I had it off & had extra laying around.
I definitely think I had this issue for a while. After getting everything back together, I noticed the exhaust sits more centered. You can see where it had been hitting.
Did a 2 hour 100% load test... all is well!
CallMeColt
1,633
So, took it out this weekend. Just before going to sleep, I checked on the generator & found some fuel leaking.
Fuel/water separator failed at the drain fitting! Tried to tighten it & it got way worse to the point I couldn't run the generator.
Glad I had the L.I.P.S. for a backup out at the off-grid place!
Replaced it with another I had & just ran it for about 2 hours. All is good now.
The military contract filters suck. Very thin metal. I will not get anymore.
Off topic...
... Here is a quick fly over of my off grid place in case anyone who has watched this thread over the years in curious.
Light in the Dark
6,430
MA
I don't use the stock separator on the machines I go through. I cut and remove the drip line and replace with a Napa Gold 3472:
Have not experienced a failure after the sale with this filter. I can say though that I have had very sporadic failures of the line that goes from the separator base mount, over to the cartridge fuel filter. That is a leak that will stop you dead in your tracks, that I think very few plan for. A part never thought about, that it would not hurt to have made up for anyones part shelf.
Edit: I have also used the Wix model of this filter (33472) and its available at a much better price: https://www.amazon.com/gp/product/B000C9TB90/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
CallMeColt
1,633
I
I had the WIX one on before this one for a few years & had no issue. I get filters for free from time to time & had a Fleetguard one that fit so that's on there now. I'm sure it will be fine.
I was thinking about having some extra fuel line & adapters on hand. If I did, I could have bypassed the filter to keep it running. might add 5ft of 5/16 line & some fittings to the parts bag for this.
CallMeColt
1,633
Funny, it has been so trouble free I didn't realize I was way past due for an oil change! I'm at 618 hours now.
After using it this past weekend, I realized I needed to change the oil and spend a little time with it doing some minor things to it along with the trailer, but I will only talk about the generator here.
I'm pretty sure that after the many years of owning this, I found the culprit for the very minor oil leak... the 90 deg fitting for the oil drain.
Figured I would tighten it or swap it out while changing the oil. Right became loosy! The reason why it was leaking was someone cross threaded the fitting when installing it or over tightened it.
After quite the match getting it off, found the threads in the block okay. I have a ton of fittings around and have a 1/2 NPT 90 deg fitting. The one on there is odd, like a 1/2 to 3/4 NPT. So, I had to order a 1/2 NPT to 3/4 barb fitting to mate up with what was there.
https://amzn.to/3cKrI3b
Ultimately, got it all done and it seems like it's okay now. So much oil spilled that it's hard to tell if the actual leak stopped but time will tell. I'm just glad the block was not stripped.
A while back, I had wired in a switch off the solar charger controller to add some lights inside the engine area for checking things in darkness. Got some LED lights and used a 24v to 12v converter that I had laying around and started putting some in. I will run more at a later time, but having some on the important side where the oil dipstick and most of the wires are is good for now.
302257304_2212855075556572_7955749855715152650_n.jpg 304891535_1078864446350708_6902373052727288322_n.jpg 304893257_1498932063881168_3203871444922169248_n.jpg 301380191_1252221848867236_2347755660980351634_n.jpg
I'd like to get a few more of these to fix up but it seems like the days of them being reasobable are gone. Getting a commercial unit is better off it seems.
