Dsilverline
- 30
- 18
- Crestline, Ca.
Hey guys,
So, I started this project a bit ago and have been taking pictures and finding out I need to do some intersting things differently based on previous truck mods I did.
Thought it would be cool to make a thread going over the progress, getting ideas from others or showing what I'm doing (not a budget build at all ) Does that seem interesting? This project has basically taken over my life....haha
Let's see, so far in the progress I've got everything I need off the truck (needed an oxy acetlyene torch to get the exhaust manifold bolts out), almost all parts sourced and on hand, intake back installed, INJ pump turned up, new fuel return plate installed, fuel supply line installed. Now mocking up the manifold fit and trying to get everything to clear it. Found some nice little heat wrap that just fits around the fuel return lines as the clearance is extremely small on one injector due to where the port is located (port is almost on the bottom when injector is tight , is there a way to dissasemble the injector to get the ports in a diff spot?).
Also found that if you install the Nostalgic Air kit meant for CUCVs w/ two alternators and want to turbo you will run into some issues. Previously relocated the batteries to the rear of the truck and those wires caused issues also.
-In the pics you can see that the AC lines block the downpipe location (heater hoses easy to relocate). AC bracket blocks the turbo inlet ( have a plan for that)
-Nice little pile of old and new parts
-the current state after rerouting lines and heat wrapping as the clearances are so tight....(now there is room for the downpipe to get through the inside wheel well support on the outside of the frame)
