Crapgame
- 329
- 63
- Navarre, FL
You can patch that roof with the correct 2 part cement (adhesive and accellerator) plus some loose sheet of the same material. There are different types of cement for PVC and Hypalon fabric (from working on Zodiacs), I believe the US issue ragtops are a PVC base. There is a single component cement commonly used for emergency repairs but the 2 part cement lasts the longest. This shop in CA has the GI vinyl in green and tan, by the yard $23.15, then buy a small wallpaper roller (1" width x 1" diameter) for pressing out the air bubbles. https://www.ahh.biz/vinyl/vinyl_military_tent_with_ir_blocking.php
https://www.ebay.com/itm/NOS-US-Mil...224473?hash=item2cd42c2759:g:77wAAOSwuWha9vAZ
This GI Soft Top Repair Kit on ebay is expired, I don't know if I would trust the cement, and it would cure faster or slower from old chemicals. There is a card shown in that kit that shows you how much bigger than the rips you should make the patch and to round the patch corners to prevent it catching.
AquaSeal is a single component adhesive that has good reputation, the single components may work if you are planning to replace the top in a year or two anyway.
Surface to be patched needs to be cleaned and lightly scuffed, like patching your old bicycle tubes.
![Patching Instructions.jpg Patching Instructions.jpg](https://www.steelsoldiers.com/data/attachments/556/556980-875bbb354d996b188fc128d11e12c731.jpg)
Auto Car Audio Sound Deadening Application Rolling Wheel Roller, Heat Abatement Mat Wallpaper PU Deadener Application Seam Roller - - Amazon.com
www.amazon.com
