Currently i have 4 batteries seriesd to 24v and parralleled for 1500 CCA. If i replace them with 2 truck batteries with 1050 CCA will I damage the starter or anything else? If not how will this effect starting?
Thank you. I got this carquest battery: good fit and started great.Many of us run just two batteries, myself included.
When it gets cold, two might be marginal. But generally two is fine.
BCI Group Size: | 8D |
Cold Cranking Amperage: | 1155 A |
Cranking Amperage: | 1440 A |
Height: | 9.812 in |
Length: | 20.75 in |
Negative Terminal Location: | Top Left |
Positive Terminal Location: | Top Right |
Reserve Capacity: | 325 min |
Terminal Type: | Top Mount |
Voltage: | 12.0 VDC |
Weight: | 123.74 lb |
Width: | 11.125 in |
