batteries
oilworker
Ohio
Currently i have 4 batteries seriesd to 24v and parralleled for 1500 CCA. If i replace them with 2 truck batteries with 1050 CCA will I damage the starter or anything else? If not how will this effect starting?
m715mike
3,915
Montgomery, Texas
This thread is a good read:
oilworker
Ohio
Many of us run just two batteries, myself included.
When it gets cold, two might be marginal. But generally two is fine.
Thank you. I got this carquest battery: good fit and started great.
SPECIFICATIONS
BCI Group Size:8D
Cold Cranking Amperage:1155 A
Cranking Amperage:1440 A
Height:9.812 in
Length:20.75 in
Negative Terminal Location:Top Left
Positive Terminal Location:Top Right
Reserve Capacity:325 min
Terminal Type:Top Mount
Voltage:12.0 VDC
Weight:123.74 lb
Width:11.125 in
Thank you. I got a carquest battery;
  • Like
Reactions: 98G
simp5782
Feo, Fuerte y Formal
9,497
Mason, TN
Buying group 24, 31, 4d and 8Ds from your local cummins, freightliner or mack will be generally cheaper than regular auto part stores. They also have an 18mo to 24mo warranty over the 1yr warranty oreillys, napa and carquest give
My local mack sells 2yr warranty exide group 31s for $78 ea
