Scott z
- 20
- 8
- Houston, TX
This guys making really good progress through that water.
Looks like a good time. I can't say I'm ready to do that.... But I would, if the traffic was bad and I needed to get that crate of monkeys delivered.You meant this link:
I wouldn't try it on the river like that, but LMTV should be able to ford water far higher than this. It is a diesel engine, as long as the air take is higher than the water.
PS: SS prevents the link show up
xxxx://@@@@.com/view?t=sBwvY_1594056907
Replace xxxx with https
Relace @@@@ with www.liveleak
against the river even.
How much positive pressure should put in?Most trucks can easily handle that. One could easily fab up a pressurized fording system if they were worried of water penetration of steering, crankcase,etc like done on the usmc trucks
Can be made up using common pipe fittings from home depot. Everything is sent to one central fitting section and receives air from the pressure protection side of the system
+2 t o + 4 PSIG is standard for that?How much positive pressure should put in?
that a 923 used as an example?...like done on the usmc trucks...
Yes. Marine Corp trucks were equipped with this setup to pressurize the bellhousing. Transmissions. And transfer case. Some configurations pressurize the brake and axle vents.that a 923 used as an example?
Good to know !!!Under 5psi. They make 1way check valves that only allow 5psi thru when the air is added
