Went with the 1.470”. After tightening the lock nut it measured 1.466“-1.467. TM says 1.466”.Detroit Diesel Injector Timing Gauge 1.460 J1853 Kent Moore for sale online | eBay
Find many great new & used options and get the best deals for Detroit Diesel Injector Timing Gauge 1.460 J1853 Kent Moore at the best online prices at eBay! Free shipping for many products!www.ebay.com
Go get it!
Can you give/make a sketch? Sorry, I’m a visual guy...For priming the fuel system, I’ve used compressed air in the past but prefer using an inexpensive 12V inline fuel pump instead, plumbed between fuel tank & primary filter. As soon as you hear fuel being returned to the tank you can remove the pump and reconnect the fuel fittings, or like I did with my 4-53T just release the quick disconnects and turn a couple of ball valves to redirect the fuel flow to stock. Do not use the starter to prime the system, you’ll burn up all of your hard work as the fuel parts are lubricated by the fuel.
I would recommend Chevron Delo 400 in 40 wt.I’m looking at sinopec, tulux straight 40. $50.00 for 5 gallons. Thoughts?
Gonna go with that first since i’ll need to change it a couple times quickly.As long as it’s Low-Ash Detergent-type, Should be fine.
Next weekend...can I fly you up?Did you let the smoke out?
