FMTV Allison 3070 Transmission - Code 4627 Overcurrent, A-High Solenoid Circuit
Ronmar
8,401
Port angeles wa
This is what my transmission ecu looks like View attachment 815324
Thats not a TCU, that is the Vehicle Interface Module(VIM)... This is used on a WTEC2(Mid98 and earlier) and the actual TCU is over underneath the keypad control... After mid 98 they started using the WTEC3 which did away with the VIM and started putting the TCU where the VIM was located under passenger dash...
319cssb
221
Easley SC
I checked the solenoid as per TM and the result is 4.4 ohm. The harness pin M has continuity , cannon connector pin M is not shortened to any other wire or to ground. Tomorrow I'll check the in cab harness. I didn't have the entire TM with me - only a few print outs. I removed and cleaned the relays and Circuit breakers. I have a 1997 1084 w/ wtec2
319cssb
221
Easley SC
I opened up the transmission controller and was greeted with a bunch pod corrosion and disconnected components B0AB72D7-BBC9-4753-B003-E0413D0F208D.jpeg4BE479E2-E056-46F7-A11A-87FDE3146545.jpegB0AB72D7-BBC9-4753-B003-E0413D0F208D.jpeg4BE479E2-E056-46F7-A11A-87FDE3146545.jpeg81495FDE-6A88-402D-9D77-B2A179740FB6.jpegAAB4161A-5D0F-4A7E-9B64-40F84AE5A743.jpeg9D12B9B2-C534-48ED-B285-C4D42700D7A4.jpeg760874B0-3314-49F3-9F03-17A63B291C29.jpeg95B6CD02-C83A-4060-B2B2-70A4A7244672.jpegD06123FE-E919-4C30-9EBF-3607D7D5680C.jpeg50A76318-499F-4FB2-A2C6-FFC600C29213.jpeg
