2INSANE
- 824
- 93
- Belgrade, Montana
I had found this years ago and kept it in my records. Hope this helps.
6.2 torque specs
ALL in ft lbs unless otherwise mentioned.
Bellhousing - 30
Cam Gear - 75
Cam Thrush Plate - 17
Connecting Rod nuts - 48
Crankshaft Pulley - 30
Cylinder Head (3 steps) 20 / 50 / +90 degrees
Engine Mount to Block - 75
Engine Mount to Frame - 50
Exhaust Manifold - 26
Flywheel bolts - 65
Front cover bolts - 33
Glow Plugs - 156 in/pd use anti-seize
Harmonic Balancer - 200
Injector Lines - 19
Injector Nozzle - 50
Injector pump Retaining nut - 30
Injector Pump Gear bolt - 20
Injector Pump Baffle bolt - 33
Intake Manifold - 31
Lifter Guideplate - 18
Main Bearing caps inner 110 / outer 100
Oil Cooler Line to Filter - 12
Oil Cooler to Rad -25
Oil Pump Drive bolt - 31
Oil Pump Retaining bolt - 65
Oil Pan Plug - 20
Pressure plate to flywheel bolts 38-40 ft-lbs (use loc-tite)
Pulley to Damper - 20
Rocker Arm Cover - 16
Rocker Arm Shaft - 40
Starter Bolts - 35
Thermostat Housing - 35
Turbocharger to Manifold - 37
Vibration Damper - 200
Water Crossover to Head - 31
Water Pump to Cover - 31
Water Pump Plate to Pump - 16
Vacuum Pump Retaining nut - 31
Valve Covers - 16
Oil Pan bolts - inch lbs
rear 2, 84
others 204
Body Mounts - Bolts - 55, Nuts 35
6.2 torque specs
Bellhousing - 30
Cam Gear - 75
Flywheel bolts - 65
Injector Lines - 19
Oil Pan Plug - 20
Starter Bolts - 35
Valve Covers - 16
rear 2, 84
others 204
